Already happened 3-4 times. cube black in Kore board fw 4.0.3 resets all params to default.
Running latest 4.0.3 stable and updated bootloader.
Everything reset to default, even missed frame type, EVERYTHING to default.
Is there any solution to this? It is very very annoying and dangerous problem.
I just updated bootloader using mission planner but i am on 4.0.3, should i update to 4.0.4 and update bootloader again?
How can we check we have latest bootloader installed?
That is supposed to be fixed with 4.0.4-rc2. Please test it so that we can be 100% sure it is fixed.
Ok, i’ll try 4.0.4-rc2.
After installation of 4.0.4-rc2 should i update bootloader again?
Dave84
(David )
4
no need update the bootloader
graham_new
(graham newton)
6
Hi Corrado
Any updates on the reset issue after you installed 4.0.2 rc2?
Thanks!
At the moment we didn’t have any reset after updating to 4.0.4-rc2 but the drone only has around 15 hours flight time from the firmware update.
Corrado
graham_new
(graham newton)
8
Thanks for the update Corrado.
Kungsfiskare
(Kungsfiskare pals)
9
This happened to us yesterday on 4.0.5 Plane fw. Working on air speed sensor then after a reboot it would reset itself to default parameters.
Strange.
