I use version 1.3.74 and Arducopter 4.0.3.
When I select the type of the second powermodul the following error message appears
After confirming in this field I can make a selection. Measure current and voltage.
When trying to select a sensor or enter a measured value, the following error messages will appear:
If I enter the value 14 for current and 13 for voltage in the parameter list, I do not get the correct values.
Despite many searches here in the forum I could not find a solution.
Can anyone here help me to solve this problem?
Do not plug Digital or Analog PM onto connectors configured for other type of PM
If you plug an Analog PM into a digital PM connector it will stop all the I2C devices on that bus. Specifically this will stop the GPS’s compass due to contention, and may also damage the FMU (longer term).
Similarly, a digital PM plugged into a analog connector will not work, and may also damage/destroy the power module (longer term).
