Hello everyone, I’d like to know if anyone can help me with my CTUN.Dalt value problem. It suddenly increases despite a thrust command that reduces it. This happens randomly, sometimes, when I’m already in altHold mode. When I go above 1500 (md thr), the desired ctun.dalt value keeps increasing (even if the thrust command returns to 1000), and doesn’t stop until I switch back to stabilized mode.
Hell Joshua, yes, here they are. i just got some new informations after some look : just before dtun.dalt increase, uav had a lost of gps connection. I thought that althod was only taken into account baro values for altitude ? i do not think any failsafe will make it increase altitude then.
for informations, i’m working only on purpose with ekf2, and altitude is baro source only.
in althold when you have to have rc_3 or throtle on mid to keep altitude, as you can see the moment you hit 1600 it goes up so everytheng under 1400 goes down, 1400-1600 is hold and 1600+ is going up. you can adjust the threshhold but i belive the default is the values above
that may be the psc_accz_p and psc_accz_i parametars are wrong, and it seams like you have a powerfull drone but your parametars are too high and reversed
i tried to modify them several times. i really think the observated increase is linked to the loss of gps/dead recogning, but it should be only on baro altitude
If it is repeatable, then enable LOG_DISARMED=1 and LOG_REPLAY=1 and do a short flight to repeat the behavior, then post that (and turn them off when you’re done)
