I tried in both SpeedyBee F405 wing and SpeedyBee F405 Mini. Any setting, even max (127) disarms the motor at hand launch.
I presume you are using shake to wake. If so, that is a known issue with the crash detector. Plane: Fix crash detection false positive on “shake to launch” by rubenp02 · Pull Request #29390 · ArduPilot/ardupilot
That issue is 3 years old, has not been touched since recently.
You can trick it, by moving the plane with >4km/h. during the shake. I accidentally did it while practicing wing toss.
