Hi all, recently I took my copter x for it’s maiden flight and quickly it entered an overcorrection cycle with roll and pitch, included is the log file. I’m wondring if this was a result of being in loiter mode or perhaps bad tuning? Any assistance would be appreciated!
Yeah i figured as much, but is there anything else i should look pre-flight for on the next flight (i went thru initial tune and AMC setup already) my CG is close to center of props and P:W ratio is close to 7:1. Appreciate the input, anything helps.
There isn’t much to see in this log but yea, you should be in Stabilize until you can get a stable hover even if it’s a rough one. Chances are you will need to reduce the Rate PID’s (try 1/2 of default) and once a hover thrust value is established set the vertical acceleration controller gains accordingly. I don’t know how far you got with the AMC but you would encountered this early on.
