Crash Analysis Help - EKF Failures, Compass Inconsistent, GPS Dropouts (ArduCopter 4.5.7)
I recently experienced a crash during an autonomous mission and would appreciate your help in analyzing the log to determine the root cause.
Log file: https://drive.google.com/file/d/1xIwDo11VYJ04t_DFK39nqGQZwaGS4jkh/view?usp=sharing
Drone details:
  • ArduCopter version: 4.5.7
  • Flight controller: [ Cube Orange ]
  • GPS module: [ Here3]
  • ESC: [ALPHA 60A 12S]
  • Flight mode at time of crash: [GUIDED]
What I observed:
  • The drone lost altitude rapidly near the end of the flight.
  • I noticed EKF errors in the log: “EKF_PRIMARY changed”, “EKF stopped aiding”, and “yaw reset”.
  • The vibration levels spiked sharply right before the disarm, likely due to impact.
  • Motor outputs all spiked to max before the crash.
  • GPS.GCrs showed fluctuating speed and possible loss of GPS quality.
What I’m trying to understand:
  • Was the crash caused by a sensor fusion failure (EKF)?
  • Did compass or GPS inconsistencies play a major role?
  • Could battery sag or vibration have contributed?
Thanks in advance for your time and support.
Graph the RCout’s. Thrust loss on Motor 1, Motor 2 drops to stabilize and down it goes.
No, one Motor was commanded to max due to thrust loss.
Thanks again, Dave — your help really clarified a lot for me.
Just a quick question if you don’t mind:
I was using a custom mission script written with pymavlink to control the drone.
Do you think it’s at all possible that a bug in the script caused the motor 1 thrust loss?
Or from your experience, is this almost always a hardware issue — like motor, ESC, or wiring?
Blockquote
Yes, this is most likely.
