Crash after Take off
Greetings all!
I have a s550 Hex i have built. i have been trying to get a successful flight to be able to tune it.
The issue I am being faced with is moments after take off, the Hex begins to pitch forward and I have all i can do to keep it from crashing harder than it already does. I have attempted to take off in Stabilize mode, as well as ALT_HOLD. below I will post my most recent flight logs for each.
Prior to these most recent test flights, I was getting a Potential Thrust Loss (5). I changed out the ESC for motor 5 and I am no longer getting the Potential Thrust Loss error, but it is still crashing.
It would be very much appreciated if someone could take a look at these logs because I am not having any luck trying to locate the issue.
ALT_HOLD test flight
Stabilize test flight
Thank you all very much in advance for your time
