Crash after Autotune & "Prearm: ACRO_BAL_ROLL/PITCH" error
Hi everyone,
I’ve built a few drones before, but I ran into a really strange issue today that I haven’t seen on my previous builds. It resulted in a crash, and I’m trying to understand if this is a glitch or something I missed.
The Setup:
  • Frame: Holybro x650 - 15”
  • FC: CUAV Pixhawk v6x
  • Context: The drone was previously tuned and flying perfectly. I recently swapped to a lighter payload, so I reset to re-tune.
The Sequence of Events:
  1. Performed a flight to relearn hover thrust (AltHold).
  2. Initiated Autotune. It completed Roll and Pitch.
  3. I landed and disarmed after the Yaw tune started (to swap batteries).
  4. Upon rebooting to test the new tune (in AltHold), I got a blocking error: Prearm: ACRO_BAL_ROLL/PITCH.
The Troubleshooting & Crash: I don’t fly Acro, so this error was unexpected.
  • My values for ACRO_BAL_ROLL and PITCH were at 1.0.
  • I tried the documented defaults (2.0)—the error persisted.
  • The “Fix”: I randomly set them to 0.5, and the Prearm error cleared.
  • The Flight: I assumed since I wasn’t flying Acro, this setting wouldn’t matter. I armed and lifted off about 2 feet. The drone immediately had massive input lag (approx. 2 seconds) and felt like it was over-tilting (Acro behavior?).
  • It became uncontrollable due to the latency and crashed.
Current Status: Repaired the props. I reverted the Acro Balance params to default, and the Prearm error has returned.
My Theory:
I suspect the partial Autotune calculated ATC_ANG_RLL_P and PIT_P values that were mathematically incompatible with the default ACRO_BAL parameters (hence the prearm failure). By lowering ACRO_BAL to 0.5 to bypass the check, I likely masked a deeper issue - potentially critically low P-gains or a corrupted tune - which caused the sluggish response and “lag” in the control loop during the test flight.
Can anyone confirm if this relationship exists, or help me understand what happened?
Thanks for the help!
