Could anyone share flight logs of drones hovering reliably with only single optical flow?
Please share flight logs and corresponding videos of aircraft that achieve excellent hovering stability with single optical flow positioning. My drone drifts badly when hovering and fails to hold position steadily. I hope to identify the root cause through comparison and analysis. Thank you all.
I think the better way is if you share your logs and description of your setup.
In this case more user can help you out of their experience
