Correct IMU temperature calibration
Hello!
Suggest the correct IMU temperature calibration sequence.
What should be the minimum and maximum temperature? Is it necessary to cool the FC before calibration and then heat it during calibration?
Thanks!
The correct sequence is explained here on section 4.1
That depends on the temperature range that you vehicle is expected to operate. We recommend -18°C to 50°C. These are easily achieved with normal household refrigerators.
yes.
No, usually the boards have a heater. Or if not, the environment will do that for you.
