goredhawk
(Goredhawk)
October 29, 2018, 2:14am
1
Hi there,
I get a UAVCAN GPS , last weekend, i try to test it with a Pixhawk4 (Holybro) , fmuv5.
And i just can not get GPS data with ArduCopter v3.6.0 Quad . Does ArduCopter v3.6.0 support UAVCAN GPS? or i set wrong parameter ?
the details as follow:
Test 1:
Hardware: Pixhawk4 (Holybro fmuv5)
Firmware: ArduCopter V3.6.0 Quad
GCS: Mission planner 1.3.59 build
param set as follow:
GPS_TYPE = 9 , set for UAVCAN.
result:
i use UAVCAN-GUI-Tool, and i get the info as followed:
As the picture show, Arducopter can not get any gps data.
use UAVCAN-GUI-Tool, i can get the GPS node id :53; in the UAVCAN_GUI_Tool the GPS data is good. but the pixhawk4 CAN node id is not available.
Test 2:
Hardware: Pixhawk4 (Holybro)
Firmware: PX4 Flight Stack v1.8.1 stable Release
GCS: QGroundControl v3.4.4
result:
i get the GPS data. And in the UAVCAN_GUI_TOOL, i get gps can node id 53 and the pixhawk4 can id:1, all is good.
Does anyone test UAVCAN GPS with arduCopter v3.6.0 ?
Anyone can give me some clue ?
hdtechk
(Kurt shaw)
October 29, 2018, 4:45am
2
Did you select GPS_type=9 for uavcan
goredhawk
(Goredhawk)
October 29, 2018, 6:04am
3
Yes, i select GPS_Type = 9, UAVCAN
Please read the ArduCopter 3.6 release notes
goredhawk
(Goredhawk)
October 31, 2018, 1:46am
5
@ amilcarlucas , thanks for reply, the 3.6 release notes, do you mean this:
yeap. I meant that post. Always read the release notes first.
skyyuzhang
(Skyyu Zhang)
November 25, 2018, 8:29am
7
where did you git uavcan gps cause I want to get a uavcan gps too
mike
(mike kelly)
December 8, 2018, 6:04pm
8
@goredhawk The cube had a problem with mislabelled Canbus ports maybe you should just check if you connect to CAN2 instead of CAN1 if it works.
Zubax makes a UAVCAN GPS and you can use OlliW’s UC4H to interface a normal serial GPS to CANbus.
High-performance board-level positioning module with compass and barometric altimeter for robots and unmanned vehicles. Zubax GNSS 2 is a multipurpose high-performance board-level positioning module interfaced via CAN bus, USB, and UART. It includes...
This interface will work with a serial GPS:
goredhawk
(Goredhawk)
December 12, 2018, 12:49am
9
goredhawk
(Goredhawk)
December 12, 2018, 1:00am
10
Hi mike, thanks for reply
i connect to CAN2 instead of CAN 1, it not works. i have try it for many times.
now i change another Pixhack V5 , and it work perfectly.
So, maybe there is some problem with the Pixhawk4 (Holybro)
this one work perfectly.
skyyuzhang
(Skyyu Zhang)
December 12, 2018, 1:57am
11
Did you get UAVCAN Battery Monitor? cuase I have benn researching UAVCAN Battery Monitor
tridge
(tridge)
January 23, 2019, 3:23am
12
I have just fixed a bug in ArduPilot that prevented CAN from working on a Pixhawk4. If you try master now it should work.
Cheers, Tridge
goredhawk
(Goredhawk)
January 28, 2019, 7:20am
13
@tridge thanks, i will test it.
can you give the bug fixed git commit link
