Copter wobble in z axis
I’m working on a Quadcopter using xing 2205.8 2300kv motor with Blheli 4in1 alongside pixracer pro.
6s 1300mah battery, Power module v6.0, Here 2 gps, Rfd 900.
The problem which I am getting is that when i fly my drone in stabilize mode it works perfectly but when I switch to loiter or any gps based modes it starts wobbling in z axis (like going up and down in z axis). And now I’m unable to find any solution to this problem. Please look into the log file if someone could help. Also I have tried changing the gps but still problem is not going off.
https://drive.google.com/drive/folders/1RjDBR2Zm1xS78t64Lv7WrrcIBCTx8ra0
This is one of the many issues solvable by the ArduPilot methodic configurator software.
Install it and use it.
I bet that is not your only issue.
Another craft with Motor output oscillation due to some default parameters. It’s rather simple to solve that but use the Configurator anyway.
@dkemxr we all statistically know, users never have a single configuration issue.
They waist a lot or time and money by trial-crash-repair-repeat. Let’s stop advising them to fix one issue at a time. Let’s do them a favor, and explain them how to fix all issues at once and without crashes, shall we?
