are you sure is a Quad+ motor layout for your 20" propeller drone? you have 6 motors configured.
FRAME_CLASS,1
FRAME_TYPE,0
SERVO1_FUNCTION,33
SERVO2_FUNCTION,34
SERVO3_FUNCTION,35
SERVO4_FUNCTION,36
SERVO5_FUNCTION,37
SERVO6_FUNCTION,38
any reason you go for battery 2 monitor and not 1 for CubeOrange?
Confirm you mounted CubeOrange and compass this way.
Are you sure you have 2 external compasses?
Make sure you did the ESC calibration.
AHRS_ORIENTATION,10 Yaw90Roll180
BATT_MONITOR,0
BATT2_MONITOR,4
COMPASS_ORIENT,4 Yaw180,
COMPASS_ORIENT2,0 ???
COMPASS_ORIENT3,4 Yaw180,
GPS_TYPE,9
GPS_TYPE2,0
MOT_PWM_TYPE,0
Double-check your propeller plane to see if there are some higher than others, if no, You may want to try simple Accel Cal on a flat surface to see if help before you arm and Calibrate level.
As @amilcarlucas suggested, double-check the motor spin direction. And also check your drone body XY-CG.
Consider this suggestion as well. Understand what you bring to your CubeOrange.
could be minor to your current values, these are the latest suggested initial parameters for a 20" propeller drone.
|Prop Size|20|inches|
|Arducopter 4.2+|||
|ATC_ANG_YAW_P|3|Changed parameter name in 4.2, see above|
|Arducopter 4.0 to 4.1|||
|ACRO_YAW_P|3|Uses new formula|
|ATC_ACCEL_P_MAX|50500||
|ATC_ACCEL_R_MAX|50500||
|ATC_ACCEL_Y_MAX|18000||
|ATC_RAT_PIT_FLTD|11.5||
|ATC_RAT_PIT_FLTE|0||
|ATC_RAT_PIT_FLTT|11.5||
|ATC_RAT_RLL_FLTD|11.5||
|ATC_RAT_RLL_FLTE|0||
|ATC_RAT_RLL_FLTT|11.5||
|ATC_RAT_YAW_FLTD|0||
|ATC_RAT_YAW_FLTE|2||
|ATC_RAT_YAW_FLTT|11.5||
|ATC_THR_MIX_MAN|0.1|Set to 0.5 after test flights|
|INS_ACCEL_FILTER|10|10 is the new default|
|INS_GYRO_FILTER|23|Usually dont go below 20|
|MOT_THST_EXPO|0.71|Uses new formula|
|MOT_THST_HOVER|0.2|Hover Learn will fix this|
