Earlier version of Copter has the STB_xxx_x listed in Full Param list.
Last version was v3.2. Since then, STB_xxx_x can only be found at the top in Extended Tuning page.
Are these param hidden somewhere in Full param list that I could not find ?
I usually bring only cell phone to field to access the param via Tower app.
STB_xxx_x after v3.2 appear only in MP which needs laptop to access.
These days, cell phone is a more handy GCS compared to laptop. Will the developer consider
putting these param back to Full Param List ?
I am running Arducopter 3.3 and later versions on several Open Pilot Revolution.
Seems not too many people run Copter on this board. If you have experience with this board, I have some questions , such as logging files on this board which does not have sd card slot.
I don’t have a Revolution board but I do have a couple boards w/o an Sd card. You need to configure for Block Logging by LOG_BACKEND_TYPE (4). You may have to use Copter 4.X for this to work and be stable. I would load current Stable (V4.0.3) and try it.
