Copter speed not increasing in SITL
I want to achieve 50m/s speed in my SITl
i am using model X and multirotor
i have changed the WP_spd to 50, angle_max to 60, SIM_BATT_VOLTAGE
12.8V but it goes only 18m/s and it only achieving the lean angle of 53 degree
if i increase the SIM_BATT_VOLTAGE to 25.6 the copter goes in roll from 0 to 10 degree below is the of the recorded video
and if i keep on increasing the voltage the copter start to behave strangly and roll also increase
@rmackay9 @Eosbandi
Hi @Jahanzaib_Aftab,
I’ve never tried to make a vehicle that fast in SITL but I suspect it can be done by adjusting the weight and thrust parameters:
There might be a drag parameter as well that could be reduced.
These paramters are not showing in the SITL my SITL is using 4.7.1 firmware version @rmackay9
and should i increase the default 12.8V bat_voltage paramter to increase speed also?
But they do in 4.8
So I managed to get the vehicle flying at 50m/s in SITL by setting these parameters:
  • ATC_ANGLE_MAX 80
  • WP_SPEED 50
  • WP_ACC 5
  • SIM_FRM_BBDRAG 0.1
  • SIM_FRM_MASS 1
  • SIM_FRM_MDRAG 0.1
  • SIM_FRM_HOVR_THR 0.2
Thanks @rmackay9 for you help brother
