I’m following this guide: Intel RealSense T265 — Copter documentation
but I’m stuck on the python part. I installed everything and figured out how to run the scripts: t265_example.py and t265_test_streams.py are returning position data as expected but t265_to_mavlink.py give me the followings:
INFO: Using default connection_string /dev/ttyAMA0
INFO: Using connection_baudrate 57600.0
INFO: Using default vision_position_estimate_msg_hz 14.0
INFO: Using default vision_position_delta_msg_hz 14.0
INFO: Using default vision_speed_estimate_msg_hz 14.0
INFO: Using camera position offset: Disabled
INFO: Using compass: Disabled
INFO: Using default scale factor 1.0
INFO: Using default camera orientation 0
INFO: pyrealsense2 version: 2.50.0
INFO: Starting Vehicle communications
Alarm clock
“Alarm clock” seems to be an error, but I can’t figure out what does it means.
The error is raised on the first attempt to use send_msg_to_gcs(‘Connecting to camera…’)
if I change the connection string with a dead one, it says it’s dead but then connect to camera and shows confidence output, but of course I don’t get VISION_POSITION_ESTIMATE on mission planner
If possible it is easiest to use the pre-built image for the RPI4 (or RPI3). This will get around all the setup problems I think. Also I would recommend using Copter-4.1 instead of 4.0.
Hi @rmackay9,
thank you for your help. I already tried the pre-build image, but it didn’t boot at all. I can try again from the moment I have now a mini HDMI cable.
I will update to Copter-4.1 too.
I’ll be back.
Even with pre-built image I’m stucked on the same script. This time I get “Connection Error! Retrying…”
If I use /dev/ttyAMA0 or /dev/ttyS0 the error show up because after 30 sec the script abort. With other ports it just spam it.
