so my problem is, the script no longer performs its intended actions. as shown in the screenshot, im receiving the same command ack result from all sorts of different commands. this pymavlink script used to work perfectly fine. im not sure what the problem is. there hasnt been any crashes, or extreme code changes since the last time the script was ran. the hardware that is running ardupilot is the px4 mini. currently running on 4.1.5 and has been for a while.
some troubleshooting solutions ive tried already include…
changing the baud rate
changing the com/localhost
adding com links
changing firmware versions
im definitely stumped,
is the pixhawk 4 mini still supported? or even allowed to be controlled by guided mode through pymavlink?
any answers or advice would be greatly appreciated
