Hi, I built myself a quadcopter (my first time) I used Cube Orange+, Blheli_s esc, 1245 propeller, radiolink gps, 4s 16000 mah, SunnySky X4108S 690KV motors. My Quadcopter total weight is around 2700 grams and total lift is I believe around 7600 grams. It was my second flight. It was very windy. I couldn’t figure out how to analysis log files. It would be really helpful if someone reviews it and point me the directions. I believe it crashed when it was in Loiter mode.
No, I configured it using Mission Planner, I did each calibration from Setup > Mandatory Hardware menu except ESCs, I calibrated them using Blheli Suite.
I didn’t connect the motors to the Power Brick Mini because in max throttle total current consumption is around 100A and I didn’t know if power brick mini is capable of that much current. So I am trying to fly based on voltage.
I mounted it with double-sided tapes included in the cube orange packaging.
If you dont mind, how could you tell it? Checking the logs or from the video? I am trying to understand how to analyze logs. What parameters are too high too low etc.
This is what you do now. Open the log in Mission Planner and graph the same fields shown in the above graph and then include Baro>Alt and you will see if the motor lost thrust before or after it crashed. The answer is before. The fault caused the crash.
It’s often not clear from a log what failed. You don’t have ESC telemetry in the log which can offer some clue sometimes.
