Copter-4.7.2 released!
Copter-4.7.2 has been released as the stable/official version for multicopters and traditional helicopters and can be downloaded using Mission Planner, QGC or directly downloaded from firmware.ardupilot.org.
Warning 1: Loiter mode supports co-ordinated turns by default. This may be disabled by setting LOIT_OPTIONS = 0.
Warning 2: ATC_INPUT_TC parameter scaling and defaults reduced compared to 4.6 which affects roll/pitch responsiveness in manual modes in Copter. If you have ever modified this parameter value yourself you will need to reduce the parameter by 33% (e.g. multiply by 0.66) to achieve the same feel in 4.7 compared to 4.6. E.g. if the AP-4.6 value was 1.5, when using 4.7 please reduce to 1.0.
The list of changes vs 4.7.1 are in the ReleaseNotes and copied below.
  1. Board specific changes
  • CoreWing F405 Wing V2 and Wing Mini V2 boards (@MakeSomeFakeNews, PR:33717)
  • CUAV-X25-MEGA board support (@cuav-chen2, PR:33475)
  • GPilot P1 board support (@gokhan-iha, PR:33067)
  • KakuteH7 and KakuteH7Mini support LSM6DSV-family IMUs (@zebulon-86, PR:34092)
  • Lectron Pi5 board support (@lectronuser, PR:33423)
  • NWBLUE_PROH757 board support (@andyp1per, PR:33349)
  • Pixhawk6X supports LSM6DSV-family IMUs (@zebulon-86, PR:33758)
  • ZeroOneX6 and ZeroOneX6_Air support bmm350 internal compasses (@ZeroOne-Aero, PR:32541)
  1. Library/Driver changes
  • Analog Devices ADIS16607 IMU support (@cuav-chen2, PR:32109)
  • Baro: bmp581 read thrice to get corrected data (@peterbarker, PR:34265)
  • Baro: MS5837 BARO_DEVID devtype fixed (@Williangalvani, PR:34339)
  • BMP390 baro init performs soft reset to clear sensor config (@crvogt, PR:33813)
  • Follow discards target state when FOLL_SYSID changes (@lthall, PR:33891)
  • Follow loses automatic sysid detection (@lthall, PR:33937)
  • GCS_MAVLink: statustext chunk tracking compid comparison fixed (@masonzeng702550, PR:34295)
  • Harmonic Quintuple Notch fixed (@IamPete1, PR:33974)
  • IIS2MDC compass fixes and enable by default (@andyp1per, PR:33780)
  • InertialSensor: LSM6DSV IMU heater not being driven fixed (@RunnyCow, PR:34116)
  • Linux CAN bus regression fixed (@landswellsong, PR:34062)
  • Linux boards read multiple UDP packets per cycle (@landswellsong, PR:33828)
  • Logger: dBm unit added to log structure (@olliw42, PR:34320)
  • OSD uses correct yaw (@IamPete1, PR:34007)
  • QMC5883P enabled on 1M boards by default (@IamPete1, PR:34101)
  1. AHRS / EKF fixes
  • Drag fusion fixed when using GPS for yaw (@IamPete1, PR:34027)
  • Inertial sensor accel board rotation kept during gyro cal (@andyp1per, PR:33988)
  • Merge zeroRows and zeroCols into P-specific form (non-functional change, @tpwrules, PR:33132)
  • Optical flow terrain scale height sign fixed (@andyp1per, PR:34360)
  • Zero wind cross-covariances when treating wind as truth, fixes DeadReckoningNoAirspeed tests (@peterbarker, PR:33326)
  1. Sub specific changes
  • Guided mode supports acceleration targets (@clydemcqueen, PR:34298)
  1. Bug fixes and minor enhancements
  • Copter: PosHold brake-to-loiter speed threshold units fixed (@peterbarker, PR:34287)
  • ATC_RAT_YAW_NTF param units description fixed (@andyp1per, PR:34122)
  1. Tool changes
  • Cygwin build upgraded to use Python 3.12 (@tpwrules, PR:32586)
  • Debian Bullseye support removed (@khancyr, PR:34336)
  • Extend compiler warning suppression to include gcc 16.2 (@Williangalvani, PR:34058)
  • Remove now-unnecessary Python future dependency (@tpwrules, PR:32531)
  • ROS2/colcon: rosdep install fixed by skipping microxrcedds_agent key (@peterbarker, PR:34285)
Thanks to the developers and beta testers who contributed to this release!
