Hi all,
We are observing a behavior change after upgrading firmware from ArduCopter 4.5.6 to 4.5.7.
Hardware**
Flight Controller: Cube Orange+
Vehicle: Quad Copter
Obstacle sensor: Rangefinder (forward facing)
Backend:
PRX1_TYPE = 4(RangeFinder → Proximity conversion) -
Data rate: ~10–20 Hz
What works
From DataFlash log / UAV Log Viewer:
RFND data present
PRX sectors populated
Obstacle distances correctly detected
Distance drops to ~0.3–0.5 m
Tested in LOITER mode
So the autopilot is clearly detecting obstacles and generating a proximity map.
What does NOT work
The vehicle does NOT slow or stop when flying toward the obstacle using stick input.
Observed behavior:
Copter continues moving forward
No velocity limiting or braking
No avoidance reaction
Important observation
The exact same parameters and hardware worked correctly in Copter 4.5.6.
After upgrading to 4.5.7, stopping behavior disappeared.
So this appears to be a behavior/logic change rather than a sensor configuration issue.
Parameters
AVOID_ENABLE = 2
OA_TYPE = 0 (also tested 1)
AVOID_BEHAVE = 1
PRX1_TYPE = 4
PSC_POSXY_P = 0.5
Logs
Logs show valid proximity data:
Obstacle distance < 0.5 m
Mode = LOITER
Yet no braking occurs.
Question
Was there a change in Copter 4.5.7 regarding proximity-based manual stick braking in Loiter mode?
Why does the vehicle not stop even though PRX data is valid and obstacle distance is well below the avoidance margin?
Is there an additional parameter required in 4.5.7 to re-enable proximity-based velocity limiting?
Thanks in advance…!!!
