Controlling servo pins through GPIO
Hi everyone, first off I just want to say that Ardupilot and the community around it is super impressive, and I’m extremely grateful to everyone here actively answering questions. I’m new to Ardupilot but I’ve been able to learn and accomplish so much in just a few months.
Unfortunately, I’ve run into the first roadblock I haven’t been able to resolve on my own. I’m flying a Mateksys H743 Slim V3 and I’m trying to control a power switchboard (from Amazon) via a three position switch on my RC.
To do this I’ve set S7, 8 and 9 as GPIOs, and I’ve written a Lua script to toggle between them (pin_switch.lua (967 Bytes)). Now this detects and reads the PWM signal from the RC channel correctly, I can see the values changing in Messages as I flip the switch, but the pins aren’t actually getting toggled. They each read 0V no matter the position. For whatever reason, the only way I can get these to work is by enabling and assigning a relay for each. I’ve set RELAY2/3/4_FUNCTION to Relay (1), and then for RELAY2/3/4_PIN I set the respective GPIO pin numbers (56/57/58). I don’t actually have the relays controlled by anything and I’m not triggering them in any way, but by doing this suddenly I’m getting my 3.3V as I toggle between the pins.
So my question is: why is this the case? Is this intended behaviour, and is there a way to accomplish the same thing without associating relay pins? This would be fine if there were more relays, but there’s only the six as far as I can tell and that won’t be enough for everything else I want to do.
Would really appreciate some help on this one! Thanks.
Ardupilot will happily do 0ms and 20+ms PWM pulses :sweat_smile: on PWM outputs.
Multimeters are typically pretty bad at measuring RC PWM voltages (on average you should get about 0.3V)
I did try that and was getting 0.33V high and 0.17V low, that explains it! So is GPIO generally not used then? This whole thing with the relays still seems weird to me, hoping someone can figure out what’s going on there.
It isn’t necessary when using Lua. 20+ms PWM will look like continuous high state for 50Hz servo, adjust accordingly if you use different servo rate.
AFAIK state during initialization is different for PWM and relay configured pins.
What’s going on is that relay maintains set state and PWM pins go low after the set duration (or not if the commanded pulse is too long :sweat_smile:)
I see, well thanks so much for the clarification! How do I adjust the PWM duty cycle like you mentioned? Can’t find any documentation or parameters for that.
You are conflating RC protocol with traditional duty cycle PWM. In Copter firmware, I’m not sure we have any options to output duty cycle based PWM. I’ll have to do a little digging to confirm that suspicion.
IIRC servos (anything except motorN) behaves like regular PWM servo unless you set DShot mask.
Duty cycle PWM is rover only I think and limited to motors (you can’t configure arbitrary servo to do that).
PS duty cycle PWM would be really nice for driving lights to avoid strobing.
Well the thing is I’m not trying to actuate a servo which is why I was trying to use GPIO in the first place. I’m going to be replacing the switchboard I mentioned in my post with a custom MOSFET switch and I’m not sure if it’ll work with RC/PWM, but I suppose the only way to know for sure is by trying!
Please read what I wrote.
RC, my bad, appreciate the clarification
HI Yuri, sorry to resurrect the thread but I’m still trying to solve this on my end. If there is no way to change the RC PWM pulse width on copter, then is there a way to use GPIO on servo pins without associating a relay? If there were more than six relays I could make do, but that quantity seems like a hard limitation based on my research.
There are four ways of using RC output pins as GPIO (mostly O :laughing:).
  1. Configure as relay and use relay bindings.
  2. Configure as GPIO and use GPIO bindings.
  3. Configure as Disabled (unassigned) and use SRV_Channels bindings to set 0 (low) or 20000+ (high) PWM value.
  4. Assign function and use SRV_Channels with appropriate range (see 3. )
Thank you so much for the fast reply :sob:, you have no idea how much that means after struggling with this for so long. Couple questions:
2 - By GPIO bindings do you mean GPIO:write()? That was what I was using originally, and it didn’t work without assigning relays to the servo pins I was using
3 - I thought Yuri was saying you couldn’t set PWM values other than 1000 and 2000us for copter? If this works this is huge! Will try this later today
I don’t think you need to assign relay outputs, -1 (GPIO) should work too.
PWM Motors are treated differently as all get the same range unless you select appropriate special output mode that tells the FC to use SERVOxx_MIN/MAX.
Strange, I wonder why it doesn’t work when I try it then. I’ll do some more tests on my end, thanks again
When did I say that?!
I said you can’t get pure duty cycle based output from an RC output.
I’m just a little baby don’t yell at me…. :disappointed_face:
Using SRV_Channels:set_output_pwm_chan() to 20000/0us for high/low respectively did the trick!! I can’t thank you guys enough, officially solved! Strangely I was able to get GPIO to work partially as well, but I think there are some timer group caveats that prevent all the pins I need from toggling correctly. Thank you again, hope both sides of your pillows are cold tonight :grin:
