Good day, Noob here.
I need some help with choosing hardware for the controller I am planning to purchase.
The boat will be controlled with a flysky fs-i6x transmitter with ia10b reciever, will this reciever
I am planning on purchasing HolyBro Kakute H7 V1.3 for a bait boat but need to be sure of the following:
I want to use the app Carp pilot pro so will this controller be able to connect to Phone or do I need to purchase additional hardware?
Will the Holybro micro M10 GPS be compatible with controller
How do I connect the battery to controller do I need to connect a power module between 3s lipo pack and controller or do I connect the battery straight to controller?
The main purpose of adding the controller to the boat will be for the boat to be autonomous so it can drop bait in the same spot automatically but I will also need to control it manually at times so both this functions will be necessary. If I want to use ground station to set coordinates will I be able to connect to the controllers built in Bluetooth and accomplish this or do I need other means? Will it be possible to connect a wifi module to the controller? if so what should I look at?
Thanks
