It seems to be working as far as flight and flight modes, android apps and telemetry are concerned but I want more (obviously).
Where I am lost is that I want to be able to control a servo with a switch on my remote.
Up to now I have only been able to identify RC10 and RC11 and cannot control them from my remote but can actuate them through gimbal stabilisation settings.
1 - what are the other outputs called on the pixhawk and the in the software?
2- how can I program it to be activated through a switch on my remote?
(my radio setup is a dx8 and a spektrum satellite receiver)
Thank you, that gives some explanations but doesn’t really link it to what I am seeing on the Mission Planner software. I have a choice of “RCXX” outputs, from 5 to 11.
I am Limited to the one output (shutter) to control a servo.
Is that right?
Is there no other way to use one of the gazillion outputs available on the pixhawk?
Right so, after looking a little more your answer has two main problems:
1st: What you said happens, just doesn’t. The available RCxx don’t change.
2nd: It doesn’t answer how to control these.
All I want is to be able to control servos through the available outputs, from my RC radio (and not the shutter as this is only good for, well…shutters).
These AUX out pins are pretty useless at the moment. I also expected to be able to use them for LED control and/or RC channel passthru.
LED out disappeared - I guess the idea was to use the “external LED” - which is unobtainium since we first heard of it …
RC passthru is a weird mess - only thru crutches like CAM trigger / gimbal control.
Maybe dump that gimbal code (servo controlled gimbals are pretty extinct anyway) and re-do the RC channel passthru in a simple, user-friendly way ? Very excited to see the dev efforts to get S-Bus channels 9-16 in - but what shall we do with these
And while we’re at it - how about giving out FrSky Telemetry protocol on one of these pins ? This got high interest: http://www.diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?id=705844%3ATopic%3A1539556&page=1#comments
