I want to control dynamixel using pixhawk 6C.
I followed same procedure in ardupilot doc - [Robotis Servos — Copter documentation]
I used XM430-W350-T Dynamixel, connected Tx pin of pixhawk telem 2(serial2) port( Tried other serial ports also).
Baud rate of dynamixel -57600bps
ID - 11
Protocol 2
Pixhawk 6C( hexacopter X config, Firmware version - 4.3.2)
I checked the Tx pin output in oscilloscope, I can’t see any UART signal.
Please help me to figure it out.
Can you attach the .param file? or list all the SERVO and SERIAL params you used.
And did you set the servos ID to the same number as the SERVO params you are using?
I tried some SERVO11_FUNCTIONs, but It’s not working. I want to control the servo using servo tab in the mission planner’s Flight Data screen. Could you please suggest which servo function that I can use?
Set it to be an RC in for testing, an unused RC channel, and set that channel to a 3 position switch or a pot on your transmitter.
Like SERVO11_FUNCTION,58 if you channel 8 was doing nothing else.
