Hi all,
I recently purchased an Orange+ Cube and am setting up the system on a test model. I had two 433 MHz telemetry modules from 3DR first generation, which worked well despite having a somewhat limited range. So, before investing a certain amount of money in two modules like the Cuav P8 or RF Design, I wanted to purchase a pair of 868 MHz Lora modules, model DX-LR03, which are quite inexpensive. Using the supplied software, I configured them transparently with a serial speed of 57,600 baud and tested the communication between the two PCs, which occurred without any problems. At this point, I created the connection cable to the flight controller, making sure that the RX and TX ports were connected correctly. However, once I attempted to connect to Mission Planner, the connection to the flight controller failed. Has anyone by any chance tried these or similar modules and can give me some advice? I’m not sure what else I could do.
Thanks in advance,
Fausto
