Connecting UDP camera to Matek FC
I am connected my camera to c1 pin in my matek. I made a connection with pc. I need to camera feed. How should I proceed ?
You do not specify which camera, which matek FC and which datalink.
fc : matek f405 vtol
camera standard fpv cam I dont know the brand
I connect via udp
How do you plan to transmit UDP over the air?
I have tethered drone
I need to somehow(if it is possible) get the feed from fc
The video feed never touches the FC unless you are using analog video and the FC has an integrated OSD.
But an analog feed is very different from a UDP feed.
So all you need to do is connect the camera to the ethernet connector of your tether system
hmm okey thank you. I think I need ip camera sort of thing
