Hi Everyone,
I’ve been trying without success to connect with a simple dronekit-python script to my drone running navio2+rp3 and Arducopter. Connection to the drone works perfectly with both QGroundControl or APMPlanner … I connect directly via the Wifi of the Raspberry since both the drone and my laptop running QGC or APM are connected to the same wifi router at home.
On Ardupilot running on Navio2 I have edited the file sudo nano /etc/default/arducopter with the configuration #TELEM1="-A udp:192.168.1.108:14550" where 192.168.1.108 is the IP address of my laptop.
The droneKit script I’m using is vehicle = connect(‘192.168.1.114:14550’, wait_ready=True) where 192.168.1.114 is the IP address of the drone on the wifi network. This script is saved on my Connect.py script and I run it on my laptop (where normally I run QGC or APM)
Unfortunately this is not working. I tried both uptions: using tpc and upd (when using tpc I simply use ‘tcp:192.168.1.114:14550’ when calling the connect function). Both are not working. I get:
Case UDP:
Traceback (most recent call last):
File "Connect.py", line 15, in <module>
vehicle = connect('192.168.1.114:14550', wait_ready=False)
File "/Library/Python/2.7/site-packages/dronekit/__init__.py", line 3159, in connect
handler = MAVConnection(ip, baud=baud, source_system=source_system, source_component=source_component, use_native=use_native)
File "/Library/Python/2.7/site-packages/dronekit/mavlink.py", line 130, in __init__
self.master = mavutil.mavlink_connection(ip, baud=baud, source_system=source_system, source_component=source_component)
File "/Library/Python/2.7/site-packages/pymavlink/mavutil.py", line 1670, in mavlink_connection
return mavudp(device, source_system=source_system, source_component=source_component, input=input, use_native=use_native)
File "/Library/Python/2.7/site-packages/pymavlink/mavutil.py", line 1015, in __init__
self.port.bind((a[0], int(a[1])))
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 49] Can't assign requested address
Case TCP:
[Errno 61] Connection refused sleeping
[Errno 22] Invalid argument sleeping
vehicle = connect('tcp:192.168.1.114:14550', wait_ready=False)
File "/Library/Python/2.7/site-packages/pymavlink/mavutil.py", line 1636, in mavlink_connection
File "/Library/Python/2.7/site-packages/pymavlink/mavutil.py", line 1169, in __init__
self.do_connect()
File "/Library/Python/2.7/site-packages/pymavlink/mavutil.py", line 1189, in do_connect
raise e
socket.error: [Errno 22] Invalid argument
The reason why I need to use dronekit-python is to get telemetry data from the drone and upload missions written in code, directly from my laptop. Do you know where am I doing a mistake? Should I configure something different in Arducopter?
