Connecting Powerbrick mini with cube Orange
im trying to get a voltage reading out of an Power brick mini.
When im trying to set up the Sensor it gives out the Error “Batt_AMP_PERVOLT” Failed and some more errors. ive tried changing the parameters manualy but i cant find them in the Parameter tree.
Thanks for any help in advance!
You will not have only a " Power brick mini." But we can’t see what you have, so how can we help.
Please show us your setup and informations about firmware and you param-file
Try reboot the hardware after enable the battery monitoring to see the rest of the parameters appears.
youre right i dont have just a power brick mini. Sorry im quiet new to this scene. But i got it setup by myself. I have it attached to a orange Cube. So on the Cube Orange “Breakout Board” the power supply/sensor inputs are labeled power 1 and power 2. So i thought that in Ardupilot they are Bat0 and Bat1. But it turned out that power 1 is Bat 3 and power 2 is Bat 2. I got the Voltage input running fine but im not getting the amp reading yet. I have some things open that could be the problem to try tomorrow. If it doesnt work I will write again.
Thanks a lot!
