Hey Team,
Scouring the forums i can’t find anyone thats encountered the same issue i have.
I’ve attached the log below. This is from a Matek 765-WSE running the latest stable build of Arduplane. I’ve set the board up clean with no external devices attached and i can’t get the onboard baro to calibrate, because it won’t pass this first config step i can’t do any further config with the board.
This will be my second 765-WSE, and i haven’t done anything different so very confused. Board is ok in every other sense, will output OSD and camera / take servo input and output control. Is this a faulty onboard Baro? Am i missing something simple?
24/04/2022 3:06:33 pm : Config Error: fix problem then reboot
24/04/2022 3:06:32 pm : Config error: Baro: unable to calibrate
24/04/2022 3:06:28 pm : Config Error: fix problem then reboot
24/04/2022 3:06:27 pm : Config error: Baro: unable to calibrate
24/04/2022 3:06:23 pm : Config Error: fix problem then reboot
24/04/2022 3:06:22 pm : Config error: Baro: unable to calibrate
24/04/2022 3:06:18 pm : Config Error: fix problem then reboot
24/04/2022 3:06:17 pm : Config error: Baro: unable to calibrate
24/04/2022 3:06:15 pm : RCOut: Initialising
24/04/2022 3:06:15 pm : MatekF765-SE 003F001C 3056500B 20333547
24/04/2022 3:06:15 pm : ChibiOS: 45395b6a
24/04/2022 3:06:15 pm : ArduPlane V4.1.6 (eddf0367)
