Compasses Inconsistent (External Compass Orientation)
arducopter
(Mehmet YILDIZ) #1
Dear Community
No matter what I do I get compasses inconsistent. I would like to ask you the orientation of external compass ( HMC5883L) . My opinion just Rotation_180 ( Because compass is upside down). Thank you for your help
Schematics Here
3fbc256bf3f21831805d3e46affc4e8d5ddd8448
153922b99ac0bb2f4e7be4327c8275f16003afbd_1_690x421
(Markus Müller) #2
Wiki says:
Checking Compass Orientation
Ensure your AHRS_ORIENT parameter is correct. This will ensure that your internal compass’ orientation will be correct
When rotating your aircraft through all axes each of the compasses should move in the same direction, and should be of approximately the same values
Northern Hemisphere: - Z-component should be positive - when pitching the vehicle down, the X component should increase in value - when rolling the vehicle right, the Y component should increase in value
Set all compass offsets to 0 and use ROTATION_NONE (usually this should be correct setting) for compass and check mx, my, mz values in ‘Flight Data’ -> ‘Status’ tab. Change rotation if necessary.
(Mehmet YILDIZ) #3
Thanks , I will check again @ultrafuge
