i try to use the APM 2.5 with Miru Mod on my AR-Drone 2.0 …
The problem is, i need the unmixed PWM Output from the APM …
I´ve try it with the Helicopter Mode…
I´ve config 2 Servos on 0° and 90° … So i became out the Roll and Pitch on seperat Channels… The Yaw Channel also works fine…
But the Problem is the collective… I need a unmixed Output for it … If i config the APM , collective in Stab Mode to max 50% and min 50% i became a unmixed output from the Roll and Pitch Channel … Thats fine…
But at last , how i can get the collective on a extra Channel ???
I did not really want to deal with the code, but ok… but i´ve think about it … I never seen befor a so complex Arduino Code, so it take a while…
I i´ve write some Arduino Codes too … But nothing like this… And i still better with Labview.
MiruMod is a RC Mod for the Parrot AR-Drone …
I try, to use the Mod to Controll the AR-Drone with the APM 2.5, so i need unmixed completely unmixed output from the APM because the AR-Drone Flight Controller is mixing his gain´s her self…
The AR-Drone self can´t fly autonomous GPS waypoints… I also like the “follow me” function …
So i just need 4 unmixed channels for , Roll, Pitch, Climb and Yaw ,
I like the controll APP´s for Smartphone … Also i like and need tu use the Interface for Labview …
And on the AR Board runs Linux… So i have some options for the future…
For example u can run a Python runtime on the AR Board so u can run some Python Code´s on it…
And at last i realy like the object tracing function.
The AR Drone can tracking and follow a symbol card with the bottom Cam.
Ok … thx for the info … I didn´t read much about PX … I also done with Moding my Drone with “Franken Drone Mod” ( Bigger Motors , LIPO´s and ESC on a bigger frame ) … So i think the information came to late for me …
But good to know … Maybe later i think about a PX …
That sounds good to me … .
What is the H1 Code ?? A custom firmware ???
Yes … the think with the PID … I´ve think about it befor … U right … it´s can be a little bit tricky
If this realy work… ther are two PID after moding… The first on ther APM and ther 2´nd on AR-Board …
I can´t adjust the PID on AR-Drone Board… There some things that i can adjust in the developer example … But i don´t know what is for what …
So thats another Problem … But if it would be easy if someone another had already done the Mod
But … step by step …
What is the H1 Code ?? where can i found some think to read or better where i can find the Code ??
