I know there was another post on this, but reading the thread, it doesnt look like it was solved.
My quad was flying fine. I added an FPV camera to it, and now its no longer working. When I connect to the cube it shows
22/1/2026 12:41:56 : Config Error: Failed to update IO firmware 22/1/2026 12:41:56 : Config Error: fix problem then reboot 22/1/2026 12:41:51 : Config Error: Failed to update IO firmware
I have flashed the drive, wiped the sim card, downloaded rover to clean the program, then reinstall 4.6.3. I have tried to install a 4.5 version and no dice. Any thoughts would be greatly appreciated.
The input is found on the GPS1 port on the carrier. Which most commonly is found on the GPS module plugged into it if you have connected a module with a safety switch.
The way I fixed this is to short the boot button and then power it. Both FMU and IOMCU status lights (amber) should be blinking. Then reinstall the firmware. I have a Pixhawk 2.4.8 and they made stuff simpler on the clones by making the boot button the same as the safety switch pin. Don’t know about cubes. You may have to open it up and short the correct pad.
Yeah, QGC works perfectly for firmware installing whereas Mission Planner sometimes fails. I had to use QGC to upgrade to 4.6.3 from 4.6.2. You can now reinstall ArduPilot and it should work
