Hi
I want to check the motor direction and connection on a X configuration quad copter. Unfortunately CLI has been remove in the 3.2 version of the firmware.
Do I have a alternative to the CLI to check the motors?
Thanks
Hi
Thanks
@mathk,
You can temporarily fall back to v3.1.5 to use the CLI and then revert back to v3.2.
Regards,
TCIII GM
Could you not use Mission planners “motor test” under “Initial setup”, “optional hardware”?
