where do I set the TERRAIN_ENABLE? I cannot find that configuration files. Internet is okay, all the libraries and packages were downloaded successfully before this issue.
I believe the issue was with the ownership and permissions for the .tilecache directory, which was located in my Home folder (it’s hidden). The .tilecache directory and its subfolders, belonged to root and did not allow write access. Everything seems to be working after using
.tilecache directory, which was located in my Home folder (it¢s hidden). The
