Can't use AirSim binaries
Hi folks,
I have spend all the day trying to make airsim work, I’m using Copter 4.5 and these are my laptop specs:
OS: Ubuntu 22.04.5 LTS x86_64
Kernel: 6.8.0-94-generic
Shell: zsh 5.8.1
CPU: Intel i9-9980HK (16) @ 5.000GHz
GPU: NVIDIA GeForce GTX 1650 Mobile / Max-Q
GPU: Intel CoffeeLake-H GT2 [UHD Graphics 630]
Memory: 5110MiB / 15614MiB
I have downloaded the last AirSim binary available 1.8.1 with the Blocks enviroment
I launch the binary first:
./Blocks.sh -ResX=640 -ResY=480 -windowed
Later I run the SITL with the following command:
sim_vehicle.py -v ArduCopter -f airsim-copter --console --map -A “–sim-port-in=9003 --sim-port-out=9002”
The .json of Airsim is the following:
“SettingsVersion”: 1.2,
“LogMessagesVisible”: true,
“SimMode”: “Multirotor”,
“OriginGeopoint”: {
“Latitude”: -35.363261,
“Longitude”: 149.165230,
“Altitude”: 583
“Vehicles”: {
“Copter”: {
“VehicleType”: “ArduCopter”,
“UseSerial”: false,
“LocalHostIp”: “127.0.0.1”,
“UdpIp”: “127.0.0.1”,
“UdpPort”: 9003,
“ControlPort”: 9002
the output is the following:
Starting SITL input
Using Irlock at port : 9005
bind port 5760 for SERIAL0
SERIAL0 on TCP port 5760
Waiting for connection …
Connection on serial port 5760
Loaded defaults from Tools/autotest/default_params/copter.parm,Tools/autotest/default_params/airsim-quadX.parm
bind port 5762 for SERIAL1
SERIAL1 on TCP port 5762
bind port 5763 for SERIAL2
SERIAL2 on TCP port 5763
Home: -35.363262 149.165237 alt=584.000000m hdg=353.000000
validate_structures:513: Validating structures
ERROR: Floating point exception - aborting
Running: sh Tools/scripts/dumpstack.sh 30124 >dumpstack.sh_arducopter.30124.out 2>&1
dumpstack.sh has been run.  Output was:
-------------- begin dumpstack.sh output ----------------
Could not attach to process.  If your uid matches the uid of the target
process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
again as the root user.  For more details, see /etc/sysctl.d/10-ptrace.conf
ptrace: Inappropriate ioctl for device.
/tmp/gdb.30187:2: Error in sourced command file:
No stack.
-------------- end dumpstack.sh output ----------------
Running: sh Tools/scripts/dumpcore.sh 30124 >dumpcore.sh_arducopter.30124.out 2>&1
dumpcore.sh has been run.  Output was:
-------------- begin dumpcore.sh output ----------------
/tmp/gdb.30209:2: Error in sourced command file:
You can’t do that without a process to debug.
-------------- end dumpcore.sh output ----------------
I changed sudo sysctl -w kernel.yama.ptrace_scope=0 to 1 and 0 just for checking and it does not work also.
the output of the SITL itself is:
Waf: Leaving directory \`/home/diego/ardupilot/build/sitl’
## BUILD SUMMARY
Build directory: /home/diego/ardupilot/build/sitl
Target          Text (B)  Data (B)  BSS (B)  Total Flash Used (B)  Free Flash (B)  External Flash Used (B)
bin/arducopter   4016252    183549   218696               4199801  Not Applicable  Not Applicable
‘build’ finished successfully (1.764s)
SIM_VEHICLE: Using defaults from (Tools/autotest/default_params/copter.parm,Tools/autotest/default_params/airsim-quadX.parm)
SIM_VEHICLE: Run ArduCopter
SIM_VEHICLE: “/home/diego/ardupilot/Tools/autotest/run_in_terminal_window.sh” “ArduCopter” “/home/diego/ardupilot/build/sitl/bin/arducopter” “-S” “–model” “airsim-copter” “–speedup” “1” “–slave” “0” “–sim-port-in=9003” “–sim-port-out=9002” “–defaults” “Tools/autotest/default_params/copter.parm,Tools/autotest/default_params/airsim-quadX.parm” “–sim-address=127.0.0.1” “-I0”
SIM_VEHICLE: Run MavProxy
SIM_VEHICLE: “mavproxy.py” “–out” “127.0.0.1:14550” “–master” “tcp:127.0.0.1:5760” “–sitl” “127.0.0.1:5501” “–map” “–console”
RiTW: Starting ArduCopter : /home/diego/ardupilot/build/sitl/bin/arducopter -S --model airsim-copter --speedup 1 --slave 0 --sim-port-in=9003 --sim-port-out=9002 --defaults Tools/autotest/default_params/copter.parm,Tools/autotest/default_params/airsim-quadX.parm --sim-address=127.0.0.1 -I0
/usr/lib/python3/dist-packages/google/protobuf/**init**.py:37: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html . The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
**import**(‘pkg_resources’).declare_namespace(**name**)
Connect tcp:127.0.0.1:5760 source_system=255
Loaded module console
Loaded module map
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from tcp:127.0.0.1:5760
MAV> Detected vehicle 1:1 on link 0
STABILIZE> Received 1390 parameters (ftp)
Saved 1390 parameters to mav.parm
Connection reset or closed by peer on TCP socket
Attempting reconnect
\[Errno 111\] Connection refused sleeping
I’m lost, I remember that I was able to run AirSim in this laptop, maybe is a Ubuntu version related problem?
I haven’t change any code of the related parts.
Thanks in advance for your time and help!
Do you mean that “dumpcore.sh” throws the same error as above? Can you re-run this with the setting enabled and post the terminal output?
Hi, it’s not the same error aparently but I’m not able to understand the reason of the problem, here is the output that I obtain:
Setting SIM_SPEEDUP=1.000000
Starting SITL Airsim type 1
Bind SITL sensor input at 127.0.0.1:9003
AirSim control interface set to 127.0.0.1:9002
Starting sketch ‘ArduCopter’
Starting SITL input
Running: sh Tools/scripts/dumpstack.sh 9296 >dumpstack.sh_arducopter.9296.out 2>&1
[New LWP 9313]
[New LWP 9353]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007ac3b9cea42f in __GI___wait4 (pid=9363, stat_loc=stat_loc@entry=0x7ffd7d2ab588, options=options@entry=0, usage=usage@entry=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
30      ../sysdeps/unix/sysv/linux/wait4.c: No such file or directory.
#0  0x00007ac3b9cea42f in __GI___wait4 (pid=9363, stat_loc=stat_loc@entry=0x7ffd7d2ab588, options=options@entry=0, usage=usage@entry=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
        sc_ret = -512
        sc_cancel_oldtype = 0
        sc_ret = <optimized out>
#1  0x00007ac3b9cea3ab in __GI___waitpid (pid=<optimized out>, stat_loc=stat_loc@entry=0x7ffd7d2ab588, options=options@entry=0) at ./posix/waitpid.c:38
No locals.
#2  0x00007ac3b9c50bdb in do_system (line=<optimized out>) at ../sysdeps/posix/system.c:171
        __result = <optimized out>
        _cleanup_start_doit = true
        _buffer = {__routine = 0x7ac3b9c50c60 <cancel_handler>, __arg = 0x7ffd7d2ab590, __canceltype = 0, __prev = 0x0}
        _cleanup_routine = 0x7ac3b9c50c60 <cancel_handler>
        cancel_args = {quit = 0x7ac3b9e1c7a0 <quit>, intr = 0x7ac3b9e1c840 <intr>, pid = 9363}
        status = -1
        ret = 0
        pid = 9363
        sa = {__sigaction_handler = {sa_handler = 0x1, sa_sigaction = 0x1}, sa_mask = {__val = {65536, 0, 0, 0, 0, 549755813888, 0, 549755813888, 0, 551897006080, 0, 18446744073709551615, 0, 18446744073709551615, 0, 18446744073709551615}}, sa_flags = 0, sa_restorer = 0x7fa00000ffffffff}
        omask = {__val = {128, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 140726703405792, 3907209374215093159, 12928979727844091904, 140726703405792, 2}}
        reset = {__val = {6, 199, 140726703404720, 96650121917033, 140726703405104, 134981054137498, 140726703405120, 140726703404960, 140728825905153, 140726703405792, 140726703405792, 140726703405792, 140726703405792, 140726703405865, 140726703405991, 140726703405792}}
        spawn_attr = {__flags = 12, __pgrp = 0, __sd = {__val = {6, 199, 140726703404720, 96650121917033, 140726703405104, 134981054137498, 140726703405120, 140726703404960, 140728825905153, 140726703405792, 140726703405792, 140726703405792, 140726703405792, 140726703405865, 140726703405991, 140726703405792}}, __ss = {
__val = {128, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 140726703405792, 3907209374215093159, 12928979727844091904, 140726703405792, 2}}, __sp = {sched_priority = 0}, __policy = 0, __pad = {0 <repeats 16 times>}}
#3  0x000057e71c1c226d in AP_HAL::run_command_on_ownpid(char const*) ()
No symbol table info available.
#4  0x000057e71c1c2aec in _sig_fpe(int) ()
#5  <signal handler called>
No locals.
#6  0x000057e71c1bde57 in HALSITL::SITL_State::_fdm_input_local() [clone .part.0] ()
#7  0x000057e71c1be107 in HALSITL::SITL_State::_fdm_input_step() ()
#8  0x000057e71c1be277 in HALSITL::SITL_State::wait_clock(unsigned long) ()
#9  0x000057e71c1c0715 in HALSITL::Scheduler::delay_microseconds(unsigned short) ()
#10 0x000057e71c0dd81b in AP_Scheduler::loop() ()
#11 0x000057e71c0e19eb in AP_Vehicle::loop() ()
#12 0x000057e71c1bb8fc in HAL_SITL::run(int, char* const*, AP_HAL::HAL::Callbacks*) const ()
#13 0x000057e71c009cc4 in main ()
Thread 3 (Thread 0x7ac3b93fe640 (LWP 9353) "FTP"):
#0  0x00007ac3b9ce57f8 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=req@entry=0x7ac3b93fda30, rem=rem@entry=0x0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:78
        r = <optimized out>
#1  0x00007ac3b9cea677 in __GI___nanosleep (req=req@entry=0x7ac3b93fda30, rem=rem@entry=0x0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2  0x00007ac3b9d1bfaf in usleep (useconds=<optimized out>) at ../sysdeps/posix/usleep.c:31
        ts = {tv_sec = 0, tv_nsec = 1000000}
#3  0x000057e71c1be2ea in HALSITL::SITL_State::wait_clock(unsigned long) ()
#4  0x000057e71c1c0dcc in HALSITL::Scheduler::delay(unsigned short) ()
#5  0x000057e71c290466 in GCS_MAVLINK::ftp_worker() ()
#8  0x00007ac3b9c94ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
        pd = <optimized out>
        out = <optimized out>
        unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140726703407232, -6150205668983214335, 134981045184064, 11, 134981054187472, 140726703407584, 6854873326400663297, 6854873451705626369}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
        not_first_call = <optimized out>
#9  0x00007ac3b9d268d0 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
No locals.
Thread 2 (Thread 0x7ac3b9bff640 (LWP 9313) "log_io"):
#0  0x00007ac3b9ce57f8 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=req@entry=0x7ac3b9bfec80, rem=rem@entry=0x0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:78
        r = <optimized out>
#1  0x00007ac3b9cea677 in __GI___nanosleep (req=req@entry=0x7ac3b9bfec80, rem=rem@entry=0x0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#4  0x000057e71c1c0715 in HALSITL::Scheduler::delay_microseconds(unsigned short) ()
#5  0x000057e71c0e75d4 in AP_Logger::io_thread() ()
#6  0x000057e71c0e787f in void Functor<void>::method_wrapper<AP_Logger, &AP_Logger::io_thread>(void*) ()
#7  0x000057e71c1c07e4 in HALSITL::Scheduler::thread_create_trampoline(void*) ()
        unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140726703408448, -6150205668983214335, 134981053576768, 9, 134981054187472, 140726703408800, 6854874425375420161, 6854873451705626369}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
S:81
No locals.
Thread 1 (Thread 0x7ac3ba246740 (LWP 9296) "arducopter"):
        sc_ret = -512
No locals.
        status = -1
        ret = 0
        pid = 9363
        spawn_attr = {__flags = 12, __pgrp = 0, __sd = {__val = {6, 199, 140726703404720, 96650121917033, 140726703405104, 134981054137498, 140726703405120, 140726703404960, 140728825905153, 140726703405792, 140726703405792, 140726703405792, 140726703405792, 140726703405865, 140726703405991, 140726703405792}}, __ss = {__val = {128, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 9196350441231745024, 140726703405792, 3907209374215093159, 12928979727844091904, 140726703405792, 2}}, __sp = {sched_priority = 0}, __policy = 0, __pad = {0 <repeats 16 times>}}
No locals.
A debugging session is active.
        Inferior 1 [process 9296] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
[Inferior 1 (process 9296) detached]
Running: sh Tools/scripts/dumpcore.sh 9296 >dumpcore.sh_arducopter.9296.out 2>&1
[New LWP 9313]
[New LWP 9353]
0x00007ac3b9cea42f in __GI___wait4 (pid=9387, stat_loc=stat_loc@entry=0x7ffd7d2ab588, options=options@entry=0, usage=usage@entry=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
warning: target file /proc/9296/cmdline contained unexpected null characters
warning: Memory read failed for corefile section, 4096 bytes at 0xffffffffff600000.
Saved corefile ap-9388.core
I have tried also to read this output on my own but I’m still not able to understand the error.
Thanks!
This is progress. If I were you I’d keep the “dumpstack.sh_arducopter.9296.out” and “dumpcore.sh_arducopter.9296.out” and “ap-9388.core” files around for a developer to look at.
Basically, Thread 1 (called “arducopter”) encountered a floating point exception here: HALSITL::SITL_State::_fdm_input_local()
Thread 1 (Thread 0x7ac3ba246740 (LWP 9296) “arducopter”):
#3 0x000057e71c1c226d in AP_HAL::run_command_on_ownpid(char const\*) () No symbol table info available. #4 0x000057e71c1c2aec in \_sig_fpe(int) () No symbol table info available. #5 No locals. #6 0x000057e71c1bde57 in HALSITL::SITL_State::\_fdm_input_local() \[clone .part.0\] () No symbol table info available. #7 0x000057e71c1be107 in HALSITL::SITL_State::\_fdm_input_step() () No symbol table info available.
This doesn’t fix your problem but someone smart will need to take a look
Hi, the issue is right now solved, I had to enable the SIM_FLOAT_EXCEPT, here is an overview of the parameter in the oficial wiki ( Complete Parameter List — Copter documentation ).
SIM_FLOAT_EXCEPT: Generate floating point exceptions
Note: This parameter is for advanced users
If set, if a numerical error occurs SITL will die with a floating point exception.
The problem ocurrs during the inializitation, Airsim probably sends a NaN value that makes a floating exception, honestly I need to take time to check exactly where does this happen.
