Cant update firmware
I get the message “Failed to discover board id. Please reconnect via usb and try again.” When I try to install the arducopter 4.05 firmware. The Flight Controller is a Raspberry pi 4 with a Navio 2 hat that supports ardupilot. Its connected, as you can see in the photos.
This is not the way to update Navio Ardu firmware…
Go to https://community.emlid.com/t/navio2-arducopter-upgrade/10743
and change arducopter-3.5 by arducopter-4.0 in command lines
No need to create bash file, you can do all the commands from terminal and check progress of your work.
