Can't send MAVLink commands over telemetry ports
Hi! I have a Raspberry Pi 4B and a SpeedyBee F405WING and I’m trying to send and recieve MAVLink packets on my Pi with a JS script.
I connected the cables like this shown on the docs:
Ground to ground, FC RX to Pi TX, FC TX to Pi RX.
I put together this script (mostly took it from the this example on the repo)
#!/usr/bin/env -S npx ts-node
import { SerialPort } from "serialport";
import {
  MavLinkPacketRegistry,
  MavLinkPacketSplitter,
  MavLinkPacketParser,
  MavLinkPacket,
  minimal,
  common,
  ardupilotmega,
  waitFor,
  send,
  MavLinkProtocolV2,
} from "node-mavlink";
const REGISTRY: MavLinkPacketRegistry = {
  ...minimal.REGISTRY,
  ...common.REGISTRY,
  ...ardupilotmega.REGISTRY,
async function main() {
  // Create an output stream to write data to the controller
  const port = new SerialPort({ path: "/dev/serial0", baudRate: 115200 });
  // Create the reader as usual by piping the source stream through the splitter
  // and packet parser
  const reader = port
    .pipe(new MavLinkPacketSplitter())
    .pipe(new MavLinkPacketParser());
  // A flag that determines if the remote system is alive
  let online = false;
  reader.once("readable", () => {
    console.log("ready to read");
  reader.once("error", (err) => {
    console.error(err);
  // React to packet being retrieved.
  // This is the place where all your application-level logic will exist
  reader.on("data", (packet: MavLinkPacket) => {
    // Output generic debug information about this packet
    console.log(packet.debug());
    online = true;
    const clazz = REGISTRY[packet.header.msgid];
    if (clazz) {
      const data = packet.protocol.data(packet.payload, clazz);
      console.log(">", data);
    } else {
      console.log("!", packet.debug());
  // Wait for the remote system to be available
  await waitFor(() => online);
  const motorTestCommand = new common.DoMotorTestCommand();
  motorTestCommand._param1 = 1; // motor id
  motorTestCommand._param2 = common.MotorTestThrottleType.THROTTLE_PERCENT; // type of input
  motorTestCommand._param3 = 100; // throttle percent
  motorTestCommand._param4 = 1; // timeout
  motorTestCommand._param5 = 4; // amount of motors to test
  motorTestCommand._param6 = common.MotorTestOrder.DEFAULT;
  // The default protocol (last parameter, absent here) is v1 which is
  // good enough for testing. You can instantiate any other protocol and pass it
  // on to the `send` method.
  // The send method is another utility method, very handy to have it provided
  // by the library. It takes care of the sequence number and data serialization.
  console.log("Preparing to send motor test command...");
  console.log("Motor test command:", motorTestCommand);
  try {
    await send(port, motorTestCommand, new MavLinkProtocolV2());
    console.log("Motor test command sent successfully.");
  } catch (err) {
    console.error("Error sending motor test command:", err);
  port.flush((err) => {
    if (err) {
      console.error("Error flushing port:", err);
    } else {
      console.log("Port flushed successfully.");
console.log("running main");
main();
It does recieve Heartbeat and TimeSync packets but it doesn’t send any packets.
To confirm it wasn’t an issue with my code I also tried using MAVProxy following the docs
And the same thing,
tulpar@tulparpi:~ $ python3 .local/bin/mavproxy.py --master=/dev/serial0 --baudrate 115200 --aircraft MyCopter
Connect /dev/serial0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2025-04-15/flight12
Telemetry log: MyCopter/logs/2025-04-15/flight12/flight.tlog
Waiting for heartbeat from /dev/serial0
MAV> Detected vehicle 1:1 on link 0
online system 1
STABILIZE> Mode STABILIZE
STABILIZE> param show ARMING_CHECK
STABILIZE>
The log file (MyCopter/logs/2025-04-15/flight12/flight.tlog) does not contain any data and is 0 bytes.
Any guesses? Any help would be appriciated. Thanks in advance.
It was because of the port I was using, for some reason SERIAL2 RX on my board seems to be damaged, using SERIAL4 fixed my issue!
