hello, i am getting such an error, although i tried the solutions in the forum, i could not reach a result, can you help
Did you solve your problem mert ? Eğer çözdüysen bana da anlatır mısın ? Ben de aynı problemi yaşıyorum. Benimki windows ama .
Hi Mert
I fix this using the same command but instead of write “python 3” you just erase that part and the rest you leave the same.
So it will be “mavproxy.py --master=/dev/serial0 --baudrate 921600 --aircraft MyCopter”
I hope it works for you
