Can't get ESC telem working - Kakute F7 on bdshot v4.6.2, Tekko32 on BLHeli32 v32.6
I’ve changed these settings:
SERVO_BLH_BDMASK = 15 (4 motors)
MOT_PWM_TYPE = 6 (Dshot600)
SERVO_DSHOT_ESC = 3 (for extended ESC telem)
Might have changed a couple other things, can’t remember (my “modified” checkbox in MP just shows a blank page instead of all the settings I’ve changed?).
Anyway, no luck getting any data from the ESC’s.
Does your F7 supports bdshot? Does your board look the same as in the web page? Take note of the servo mapping output.
Do you want to post a photo?
Your Tekko32 is an old version. BLHeli32 v32.6 is quite old, also.
The official 32.7 version of BLHeli32 supports bi-directional DShot.
Newer firmware versions (such as BlHeli32 starting at version 32.10, and Bluejay starting at version 0.19) report some of the information above also via bi-directional DShot, using a protocol extension known as Extended DShot Telemetry.
Have you try SERVO_DSHOT_ESC,1?
Hi Jai…
Yes my FC supports bdshot - there is a firmware that specifically contains bdshot - that webpage is tiltled “F7 and F7 aio” - they pictured the aio, but the title is for both FC’s.
Post a photo? Of what?
The ESC may be “old” - what does that have to do with it? Doesn’t the BLHeli32 firmware determine whether an ESC will work for bdshot?
I have SERVO_DSHOT_ESC set to 3 (for extended telemetry) - I’ve also tried setting it to “1” - but no luck.
You are saying that I need v32.7 or higher to activate bdshot, but I had read somewhere that 32.6 was good enough (the quote was “32.7 is an improvement for esc telemetry”, implying not needed). And of course I have no way to update above 32.6 now that BLHeli32 firmware no longer exists.
So if I really need v32.7 or higher then might as well quit here. :slight_smile:
You do.
What Dave says. 32.7 is the absolute minimum.
Alrighty, that’s settled.
Thanks guys.
