I am using ArduRover 4.5.2. I am trying to set up gps for yaw using dual antenna CUAV C-RTK2HP. I need to set the location of the antenna but I can not find parameters
GPS_MB1_OFS_X, GPS_MB1_OFS_Y, GPS_MB1_OFS
Have these parameters been removed in this version. If so how I set the location effectively. If not, how can I find them. Thanks
I am having this issue with a speedybee f405 v4. Firmware V4.6.3.
No matter what I set GPS1_TYPE to (I want 25 for unicore moving baseline) I cannot get the MB_OFS values to appear.
Any ideas?
I made a custom firmware with GPS_MOVING_BASELINE enabled and it works. Not sure why this isn’t available in the stock firmware as now I will always have to have a custom build.
In any event, thanks for the heads up. This speedybee doesn’t have a compass and I wanted to use one of these cheap UM982 dual RTK units which, much to my surprise, works perfectly well.
