Post AutoTune I have been trying manually to tweak this tune to get a more stable machine but now have run out of ideas and ask for some help.
It is a 9kg quad, T-Motor U8ii 190Kv motors, Alpha ESC, 2815 poly carbon props, custom frame, Orange Cube.
Post autotune it was quite twitchy and in Loiter almost unstable after a high-speed stop as it would overcorrect and do a final big correction.
The tuning steps I followed were.
- Set the Throttle Based Harmonic Notch and Altitude Hold test
- Autotune AUTOTUNE_AGGR 0.05. Got some ‘Can’t level, Manually tune’ messages but it completed all axes.
- It was too sensitive so increased pitch and roll D from 0.001 to 0.01 which improved things.
- Actual Pitch and Roll and Desired Pitch and Roll didn’t line up. Improved by increasing I so it is 2 x P??
- Loiter – Instability and twitching when stopping.
- This was improved by reducing PSC_POSXY_P from 1.0 to 0.3.
- There was a small twitch at the end of the correction which was fixed by reducing LOIT_BRK_ACCEL from 100 to 50.
- LOIT_BRK_DELAY set to 0.0.
The quad now flies quite well in Stabilized but there is still quite a bit of instability in Loiter which I would like to fix.
If anyone can suggest further improvements, it would be appreciated!
https://drive.google.com/file/d/1K0JvmeghoLAs9Ng01TTP9kx5bGZA4EwS/view?usp=sharing
