Can´t build Copter4.0.6
I have set up the build environment according to the documentation and am able to compile the master branch and use SITL no problem. However if I want to build a stable branch, some critical files are missing and am unable to compile the code. Why?
So if I do
git checkout master
./waf configure --board CubeBlack
./waf copter
it works as expected, but if I try to build Copter-4.0 it does not, because some files are missing
git checkout origin/Copter-4.0
./waf copter
I have attached the error messages the compiler gives: Compile error.txt (15.9 KB)
Do a distclean and update your submodules after switching to the new branch
./waf distclean
git submodule update --init --recursive
