Holybro pixhawk 4 control neopixel?
I change to
・servo5_function = 120
・NTF_LED_TYPES = NEOPIXEL
But LED can’t flash
I change to
But LED can’t flash
Did you give it the correct voltage? Can you describe your setup a bit more?
Better use an external 5V supply. Don’t supply from possibly tiny internal components inside the Pixhawk.
You might have an issue with the signal level.
Look at the wiki for options:
https://ardupilot.org/copter/docs/common-serial-led-neopixel.html
