I have a problem. I built a little copter and it flies fine. Now I added a Holybro Radio to test Follow mode. The Radio works fine.The problem is I can not find the FOLLOW_ENABLE Parameter in the Mission Planner to setup the Follow-Mode. I use:
MP 1.3.83
Arducopter V4.6.3
FC Matek F 405 Wing V2
I allready searched for a solution in this forum and in the WWW but did not find one. Does anyone have a idea what this could be?
Follow mode is not enabled by default for F405 Wing. You can build custom firmware and enable the mode (under the Copter section) on https://custom.ardupilot.org/.
