Good morning friends. My question is regarding whether it is possible to reset factory settings my plate “apm”?
and if this is possible as I should?.
thank you very much
Greetings!
thank you very much
Greetings!
[quote=“RabbitStu”]you can use reset command in the CLI in mission planner.
code.google.com/p/arducopter/wiki/AC2_CLI[/quote]
RabbitStu. thanks for your help. problem solved
doesn’t the reset button on the 2.5 APM board erase everything and start all over ? 2.6 the same ?
@pilotgene1,
The reset button on the APM just causes a reboot of the processor and does not rest the eeprom to factory values.
Regards,
TCIII GM
