I have a few other Arduplane equipped planes, so I think it is possible, and likely done, I just don’t know how to word it correctly for search.
What I would like to do is use a small flight controller, maybe 20x20mm, or 30x30mm to use as a simple 2D/3D flight stabilizer, like the old Eagle Tree Guardians. It had 3 modes; Off / 2D / 3D. Off is off, so like Manual in Arduplane. 2D self levels after you release the sticks, so like Stabilize, And 3D would be like Acro, where it will try to hold attitude when you release the sticks. It has 3 pots to adjust gains for the 3-axis stabilization. And a master gain knob to set how much the stabilizer does. It sounds like this can be done , and then some, with Arduplane. Just looking for a recommendation for a flight controller, doesn’t need to be high powered, or a lot of memory. I guess GPS and RTL would be nice, but I don’t really them, of battery current. It’s for a LOS plane.
Suggestions, ideas, recommendations?
Rusty
