Is there anybody that tries (or succeed) to implements a cable bot with Ardupilot?
https://avr.icube.unistra.fr/index.php/Commande_des_robots_parallèles_à_câbles
Is there a specific reason why you need Ardupilot?
Because I’ve seen something similar based on a 3D printer… And since a robot like this depends more on inverse kinematic than stabilisation etc I would try with a 3D printer firmware like Marlin…
Something like this: https://www.youtube.com/watch?v=gPvIHsF13D4&ab_channel=ThomasSanladerer
Thanks for your reply.
In fact I’m thinking if it is possible and efficient to inverse the problematic of cable bots.
Use stabilisation, GPS position, … To move a cable bot
To be honest I still don’t get why you need ardupilot…
You achieve a stable position if there is no play in the cables…
You’re restricted to a specific area within a local coordinate system (every 3d printer works with a local coordinate system, that’s basically G-Code…), and if you really need the global coordinates I’m pretty sure that it should be fairly easy to convert them…
So I think everything you need already has been done, but not in ardupilot…
Every 3D printer gets its position to go to as a x, y, z coordinate, the printer than handles the inverse kinematic to reach this point
Thanks…
I don’t “need” Ardupilot… I just would like to know if it’s possible and/or if there is an interrest to do so.
I think you reply my question!
