Burning Cash on SpeedyBee
I was once very passionate about building my first drone from scratch and making it autonomous without a remote control. I learned fast and spent money faster on SpeedyBee FC/ESC stacks for multiple reasons:
  1. I shorted my first BLS F3 50A ESC (my fault) :person_shrugging:
  2. I bought a BL32 50A ESC only for it to be discontinued :sob:
  3. I then bought the F405 V4 / BLS 55A only to brick it :face_with_symbols_over_mouth:
    • Speedybee has the C2 interface solder pads, so I can still recover it.
I’m very demotivated as I put a lot of work into this project (as you can see from my GH repo) with no flying drone.
Note: For the reader’s confidence, I have successfully flashed between multiple different firmwares on the FC (Ardupilot, BetaFlight, INAV) and ESC (BLHeli, BlueJay) and got the motors spinning via Betaflight-configurator.
Enough whining and let’s be adults; I am happy to buy another ESC to continue my dream, but I want this to be my last donation to SpeedyBee for quite some time. So how can I be sure my setup?
Assuming I have the simplest flashing setup:
  1. Battery connected to ESC (with capacitor across terminals)
  2. FC ESC connection via 8-pin cable
  3. Laptop connected to FC via USB-C for flashing both ESC and FC
Note: I noticed that to flash BlueJay onto the ESC through the FC, the FC must be running Betaflight. I tried with Ardupilot, and it didn’t work until I re-flashed Betaflight onto it.
Realistic flashing setup:
  1. Motors soldered to the ESC
  2. A distance sensor soldered to the FC over SDA and SCL pins
I assume these are normal flashing conditions and did not cause the failed flash to ESC?
Final questions
  1. Should I even bother flashing BlueJay onto my new ESC, since BLHeli was working fine until then?
Note: BlueJay supports RPM filtering and EDT telemetry and is the recommended ESC firmware for 8bit ESCs
  1. Was I unlucky with my 3rd ESC or am I really making a mistake in my wiring diagram, the flashing process, or the firmware compatibilities?
BlueJay is really much better… it can give you RPM and ESC temperature.
Not sure what you meant by drawing Bat and Current going to UART?
How do you know you bricked it?
I assume you know that to read ESC data using esc-configurator you need the main battery be connected to the ESC… I once spent 1 hour trying to figure that out…
I have 7 ESCs from Speedybee (60A), no problems so far, one was running at continous load of 25 A x 4
Yeah, I figured since even SpeedyBee recommends it over its own firmware :rofl:
Good point, I updated my wiring diagram according to the SpeedyBee docs. This is the provided 8-pin cable anyway, so I am not making a mistake here.
I linked this issue I filed under esc-configurator’s GH with the screenshots and logs, but basically (in the v4 ESC version) there are no C2 interface pins for me to recover, and I cannot connect to the ESC via esc-configurator.com (web version or Debian app). When I plug the ESC into the main battery, (at least one) of the ESCs make noise so maybe I didn’t brick it???
I am using the main battery connected (soldered) to the ESC with the capacitor across the leads.
I wish.
I am not sure about betaflight at all, but with ardupilot you have to:
set SERVO_BLH_AUTO to 1
and enable the motors in SETUP, Motor 1…4 as 1…4.
Then you have to disconnect MP, and then run ESC-configurator.
For a simple copter, I would not bother with Blue Jay, especially if you have problems flashing it.
This is helpful as I plan to have my final setup be Arducopter and BlueJay!
There are few things that are easy (or inexpensive) about this endeavor.
If you’re having fun and meeting your goals - continue.
If not - reevaluate.
I like this endeavor because there’s no ā€œfinish lineā€ - there’s always something to learn or improve.
Is your current ESC BLHeli-32 or BLHeli-S.
If it’s BLHeli-32 then just leave it. It is possible to flash to AM32 but at this point what I’ve read suggest that’s not for the faint of heart. As long as the ESC has a real verson of BLH32 then you’re okay. (some boards after the shutdown of BLH32 were sold with dev versions of the firmware. If you have one, get your money back)
If it’s BLHeli-S then I would consider switching to BlueJay. Then you can run Bidirectional DShot. This means you can get simpler, effective filtering and you don’t need the extra telemetry wire.
Flashing AM32 on a BlHeli board is likely the fastest way to burn more cash for those already prone to releasing the magic smoke.
I bricked an AM32 board once by loading the wrong firmware. I then tried to recover it with pogo pins (as you would use to do an initial conversion from BlHeli to AM32). I’m pretty confident with this type of work, and it proved impossible. Do not recommend.
It sounds like you’ve had a tough ride with your drone build, but your determination is commendable! With your background in flashing different firmware, it would appear that your flashing setup should work in theory, particularly with the Betaflight re-flash to support BlueJay. Perhaps the problem lies in the particular compatibility between your ESC and firmware or a potential wiring error in the process. Since BlueJay supports RPM filtering and telemetry, it’s a good option for 8-bit ESCs, but if BLHeli was already functioning well beforehand, it could be an option to consider if you absolutely need BlueJay for your existing setup. Your wiring and flashing configuration appear to be standard, but I would suggest double-checking the connections between your ESC, FC, and flashing process, particularly that the distance sensor or peripherals are not causing interference. If you’re still having problems, the C2 interface pads on the SpeedyBee ESC could be your best hope for recovery. For future buys, perhaps stick with a more dependable ESC brand, but be sure to check firmware compatibility before purchasing another. Keep going, and good luck completing your build!
Has anyone successfully passed through and made a configuration change on the SpeedyBee ESC (BLHeli_S)?
