When I build ArduCopter the following error is returned:
/ardupilot/libraries/AP_RSSI/AP_RSSI.cpp:18:20: fatal error: utility: No such file or directory
#include
This seems a syntax error, since utility is not a library isn’t it?
I’ve cloned the source code using
git clone github.com/diydrones/ardupilot.git
Then I open ardupilot and ArduCopter folders.
Finally I use the following instruction
make px4-v2
Everything is Ok, but when AP_RSSI.cpp is built the error is returned
Do you know if theres some error in this version of Ardupilot?
Best regards
Jose Luis
