I’ve posted this in the ArduCopter (Building older versions - #10 by jmb275), but am not getting answers. I figured the development team might know better.
Bottom line is, on a MacBook Pro (circa 2018), with macOS 11.2.3, and python 3.9.1 executing the following:
git clone --recurse-submodules GitHub - ArduPilot/ardupilot: ArduPlane, ArduCopter, ArduRover, ArduSub source
git checkout Copter-4.0.7
git submodule update --init --recursive
./waf configure --board CubeOrange
./waf copter
yields the following error:
Waf: Leaving directory `ardupilot/build/CubeOrange'
Build failed
Traceback (most recent call last):
File "ardupilot/modules/waf/waflib/Task.py", line 338, in process
ret = self.run()
File "Tools/ardupilotwaf/mavgen.py", line 62, in run
if mavgen.mavgen(mavgen_options(), [xml]):
File "ardupilot/modules/mavlink/pymavlink/generator/mavgen.py", line 143, in mavgen
xml.append(mavparse.MAVXML(fname, opts.wire_protocol))
File "ardupilot/modules/mavlink/pymavlink/generator/mavparse.py", line 427, in __init__
m.crc_extra = message_checksum(m)
File "ardupilot/modules/mavlink/pymavlink/generator/mavparse.py", line 454, in message_checksum
crc.accumulate_str(msg.name + ' ')
File "ardupilot/modules/mavlink/pymavlink/generator/mavcrc.py", line 34, in accumulate_str
bytes.fromstring(buf)
AttributeError: 'array.array' object has no attribute 'fromstring'
It would appear that perhaps the wrong version of mavlink/pymavlink
is connected with the Copter-4.0.*
tags or something. The other thread referenced above has more details. I’ve tried about every permutation of the commands I can think of and nothing seems to work. BUT a clean clone of branch master
does build on my machine, so it’s not an issue with my setup (I don’t think).
I assume I’m missing something obvious.
